ONEX #54 Web Site
Date:  4-6-2013
Manual Reference:  L02
Brief Description:  Final fit of nosegear mount
Made final shim adjustments where the L02-12 tri-gear mount fits the motor mount. When things were bolted up, there were some gaps at the interface. I could have forced things into place by honking on the three bolts and risk binding the gear swivel, but opted to "bed" the gap with Blue Magic QuikSteel steel reinforced epoxy putty. The material has 18kpsi compression strength. I greased the tri-gear mount face and bolts, layed a bead of the putty around the motor mount contact area and assembled everything. Tightened all the bolts to eliminate all play, and let the putty harden. Excess extruded putty was trimmed before it fully hardened. Working time is only 5 minutes, so needed to have everything greases and ready to go prior to starting. Well after the putty hardened the greased bolts and tri-gear mount released easily.
